Activity Forums Apple Final Cut Pro Legacy Export Sequence Cuts
  • Export Sequence Cuts
    Posted by Matthew Joal on January 25, 2008 at 6:26 pm
    I have captured my tape in final cut and I want to create several smaller clips from that tape. I have used the Razor blade and cut where I needed to to make each clips. There are 14 total cuts. Is there a way that I can export all the clips to self contained movies from one sequence or do I have to create a new sequence for each clip and then export it?
    Paul Escandon replied 18 years, 8 months ago 2 Members · 2 Replies
  • Paul Escandon
    January 25, 2008 at 11:02 pm
    Hey there,
    I have a much easier way for you.
    1. Open up the export queue (Window > Export Queue)
    2. Drag the clips either from your timeline or browser into the export queue.
    3. Click the settings button in the export queue and check the Use Item In/Out box.
    4. Export.
    You’ll have new files just using the In and Outs you assigned in the clips.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • Paul Escandon
    January 26, 2008 at 12:44 am
    I’m in FCP 5.1.4 right now and this method works.. so I’m not sure when they “added” this or if it’s always been possible.
