Activity Forums Apple Final Cut Pro Legacy Export sequence at 1440 x 1080
  • Export sequence at 1440 x 1080
    Posted by Thomas Clayton on April 26, 2009 at 6:18 pm
    Hi
    I have some image sequences that I have used in 2D and 3D programs for special effects over the l ast two weeks. I exported from FCP and have images 1440 x 1080, which is what I need.
    Today I have tried many ways to export but all sequences are 1280 x 720. Research in the manual says the exports are 72 dpi. Opinions on other web pages say 72 dpi and others say export/image sequence exports at the resoultion of the original clips in FCP.
    naturally I’m coming up on a deadline and need to make 1440 x 1080 image sequences for background images in some 3D work.
    Is there trick I used before and have forgotten in the last two weeks?
    FCP 6, doing File/Export/Using Quick Time Conversion/Image Sequence
    I’m using png, 30 fps; there are no options for image size. If I freeze frame in FCP it is the correct resolution, but I can’t save freeze frames one at at time to make my image sequence.
    Thomas
    Thomas Clayton replied 17 years, 4 months ago 2 Members · 2 Replies
  • David Roth weiss
    April 26, 2009 at 10:56 pm
    Thomas,
    Your still image seqs. will be exported at the pixel dimensions of you sequence. Check your sequence settings. If they are 720p, at 1280×720, rather than 1080i, at 1440×1080, your stills or image seqs. are going to export at that size.
    Since I’m not there sitting beside you, I can only hazard a guess, but it sure seems to me as though you mistakenly created your present seq. at 720p. Is that it?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Thomas Clayton
    April 30, 2009 at 9:32 am
    The current sequence is 1440×1080 according to the bin browser. The stills are rendered at 1280×720.
    But…I just found out I can use 1440×1080 .mov files in the 3D program and it handles them like a series of stills. So I’m in good shape…..until I need FCP to make a still in the resolution of the sequence.
    Thomas Clayton
    MFA Student UNC Greensboro
