Activity › Forums › Adobe Premiere Pro › export seq from prem 6 to audition to create omf, crashes audition?
Posted by Christopher Tegg on May 17, 2013 at 7:01 amAny ideas people, will be so much appreciated.
Chrispyteggal
Christopher Tegg replied 13 years, 4 months ago 2 Members · 4 Replies -
Kris Merkel
May 17, 2013 at 1:38 pmHow are you trying to send your audio to audition, and are you creating the OMF out of Audition or creating it from PrPro “export OMF”
You indicated that you are using “export” but the quickest way is to select the “Edit in Adobe Audition” from the Edit Menu.
“Think of everything in terms of building capacity.”
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W -
Christopher Tegg
May 17, 2013 at 6:31 pmHi thanks.
Well I have been sending my cut to audition from prem 6 to create an omf.
I used the edit in audition function.
It seemed to take ages for a 10 min cut?
I have a two and a half hour cut to do.
When i got it to audition I tried encapsulated and reference.
encapsulated crashed, reference was fine.
Which is the best to use anyway.
Chris -
Kris Merkel
May 17, 2013 at 8:49 pmAh, you are exporting your video as well, that is why it is taking such a long time as it prepares your video for audition. You will want to use the reference setting if that is quicker. Edit in Audition creates an XML file but i really am not sure what it is doing with the video as it seems to be encoding the video for use in audition, maybe someone else can clarify.
The XML file lives in the Adobe Premiere Pro6.0ProjectsAdobe Audition Interchange folder there may be a problem with the default file path or it may just be too slow a data transfer rate.
Try changing the path for the xml file and see if that helps.
Kris Merkel
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
