Activity Forums Adobe After Effects Export Script
  • Export Script
    Posted by Martyn Morris on August 15, 2007 at 3:24 pm
    Hello.
    Does any one know how to export a comp as photoshop layers or know of any script that will allow me to do this.
    I know I could export as a sequence and build them up as layers in PS but this seams to be a time consuming method.
    Any help would me very much appreciated.
    Thank you.
    Martyn.
    Martyn Morris replied 19 years, 1 month ago 2 Members · 2 Replies
  • Jeff Mcbride
    August 15, 2007 at 6:13 pm
    If you only need a single frame with Layers do this:
    Go to Composition –> Save Frame As –> Photoshop Layers
    If you need all frames with layers, I believe this will do it for you, but haven’t tried it myself.
    https://www.redefinery.com/ae/view.php?item=rd_RenderLayers
    Good luck!
    Jeff McBride
    Motion Graphic Designer/Editor
    LimeGreen
    Chicago, IL
    http://www.limegreenproductions.com
  • Martyn Morris
    August 16, 2007 at 10:53 am
    Hi Jeff,
    thanks for the reply.
    I installed the scripted it’s great for getting all frames as single files quicker than rendering them via “Composition –> Save Frame As –> Photoshop Layers”.
    Whilst pulling my hair out wondering how to make them in to one photoshop document, I found that PS CS3 has a script that that stacks single files into one PS doc. Yippy!!!
    And you can download a CS 2 version here
    https://morris-photographics.com/photoshop/scripts/import-folder.html
    Thanks again Jeff.
    Martyn.
