Activity Forums Apple Final Cut Pro Legacy Export Quicktime movie wont export full video
  • Export Quicktime movie wont export full video
    Posted by Lawrence Ekin on November 21, 2010 at 11:53 pm
    When trying to export by doind export , quicktime movie it only exports 4 seconds of my timeline but when i do using quicktime conversion it exports the whole timeline but from what i understand this compresses it and causes some lost quality as i need full quality when trying to export to web . this is really frustrating and help would be appreciated im pretty much sure highlighting or in and outs etc arent the problem it does the whole thing when using conversion just not when saving as movie
    Thank You
    Chris Gordon replied 15 years, 5 months ago 4 Members · 4 Replies
  • Kenny Miracle
    November 22, 2010 at 5:25 am
    Not sure why it’s only exporting 4 sec, but I always export QT Conversion. You just need to manually set your video/audio settings to match your sequence settings. Then you can compress the full quality QT file to a web format via Compressor or QT Pro.
    QT Conversion takes a bit longer, but personally I like being able to customize my settings & I think the quality is a bit better. Of course quality is up for debate, tho.
    Kenny Miracle
    http://www.kennymiracle.com
  • Walter Biscardi
    November 22, 2010 at 12:04 pm
    Do you have an In and Out Point set in your timeline? That’s the only way I know of to export only a portion of your timeline.
    Using QT Conversion is definitely not the best way to export a timeline for use on the web because you have limited controls. We use the Quicktime Export function and then send the video into Compressor or Telestream Episode so we have full control over the compression.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
    Blog Twitter Facebook
  • Lawrence Ekin
    November 22, 2010 at 9:54 pm
    im pretty much sure it dosent have to do with things being selected or not because when i do conversion it does the whole thing but movie it does a couple seconds …
    So if i do conversion i can still have a full quality video if i do manual settings? i had just read somewhere it compreses it and loses quality, ive tried messing around with it and it looks fine in quicktime but once i put it on the web it seems to not be as good quality as a video id done with the same camera but exported on a different computer using mpeg streamclip to compress for youtube on both
    thanks for the responses
  • Chris Gordon
    November 25, 2010 at 2:37 am
    The Quick Time Export will create a reference video which really just points back to all of your original sort material and whatever you’ve had to render out. This should not affect quality at all, but the video won’t play on anything other than your machine since it doesn’t actually contain the video clips, but just points to them. Quick Time Conversion will encode everything into a completely new file with whatever settings you choose. You can then hand this file to anyone to watch (or post to YouTube), but there is some amount of loss, however small, due to the encoding pass. The amount of loss depends on the settings you choose. Something like Compressor (as Walter suggested) should give you even more control over the output and probably better quality than the QT Conversion in the editor. If you’re going to go the Compressor route, then the reference movie is a better option since you only encode the video once. Going through QT conversion and then to Compressor (or MPEG Streamclip) results in multiple encodings and the potential for more data loss.
