Activity › Forums › Apple Final Cut Pro Legacy › Export Quicktime Movie Issue
  • Export Quicktime Movie Issue
    Posted by Jon Shelson on October 16, 2009 at 3:56 pm
    I’m having an issue where whenever I export an H.264 directly from FCP it will only export from 0:00 to 1:30 regardless of where my In and Out points are set. I’ve had this issue in multiple sequences and projects.
    Jon
    Eric Johnson replied 16 years, 11 months ago 3 Members · 2 Replies
  • Tom Wolsky
    October 16, 2009 at 4:32 pm
    Did you trash your preferences?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Eric Johnson
    October 16, 2009 at 5:30 pm
    Unless there is a reason you need to go straight to H.264, export the sequence at Current Settings and convert that to H.264 using either Quicktime, Compressor or MPEG Streamclip.
    That way you can at the very least the sequence delivered, and trouble shoot during the encode.
    In response to your question though, I have had dodgy luck at best using the QT conversion export in FCP. It does a much better job of spitting it out how it was cut. Which then allows you to easily convert to something else. In some cases, going to the intermediate then compressing can be faster than, or at least comparable to, doing in one step.
