Activity Forums Apple Final Cut Pro Legacy Export Quicktime Full Quality appears Poor
  • Export Quicktime Full Quality appears Poor
    Posted by Joshua Lim on January 11, 2006 at 11:59 pm
    hi everyone,
    i tried to export a miniDV PAL project using the export quicktime, make movie self contained. I am hoping to get a full quality movie for my compositor and colorist.
    however, the image appears grainy and the fonts created from livetype look blurry.
    is this correct? Can finalcut pro 5.0 export a full quality movie or is exporting to tape the only option.
    i shot my film on a panasonic dvx100A (25p PAL) and imported as DV PAL. Is the problem in the import? did i lose my quality there already?
    really appreciate and insight! thanks a billion!
    Joshua Lim replied 20 years, 7 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    January 12, 2006 at 2:22 am
    The quality of a no change setting self contained QT movie should be the same as you’d see with your sequence playing externally on a video monitor after a render. Is it?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Joshua Lim
    January 12, 2006 at 7:36 pm
    hi jerry,
    thanks for responding!
    unfortunately, i don’t have an external monitor to view the movie.
    however, when i view the movie on full screen mode in finalcut pro and later after the export on quicktime pro, the latter looks more grainy and words look blurry.
    thanks,
    joshua lim
  • Kevin Monahan
    January 12, 2006 at 9:44 pm
    You don’t have a monitor? Then use a standard TV set. Surely, you have one of those.
    If you want to see the high quality version of your video w/o monitoring properly, you’ll have to jump through a few hoops to see it on your computer desktop.
    In QT:
    Window>Show Movie Properties>(Click on the file in the dialog)>Choose “High Quality”.
    Probably the #1 confustion in FCP-land can be avoided if you monitor your video using a proper setup with a video monitor (or at least a TV) attached to your system as you edit. Many people wrongly do not do this. It’s in the manual, however.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Joshua Lim
    January 13, 2006 at 6:00 am
    thanks for your message!
    i have a tv but i don’t have a miniDV pal camcorder to hook up my imac to the tv.
    is the image seen on the desktop (in QT or finalcut pro) is usually a lower quality than what it actually is?
    is it fair to export the movie in finalcut pro (via quicktime and NOT quicktime conversion) and use it as a full quality version of the film to give to a compositor? i.e. this method is no different from digitizing to a miniDV tape and passing it to the compositor.
    really appreciate your insight, thanks a lot!
    joshua lim
