Activity › Forums › Apple Final Cut Pro Legacy › Export Quicktime
Export Quicktime
Posted by Scott Skaja on December 29, 2007 at 9:01 pmI have clips that were captured at Uncompressed 8 bit NTSC. I am exporting portions of these clips. When I get to the Save dialogue box of the Export Quicktime process, the Setting pulldown defaults to the first choice (Apple Intermediate Codec 1080i50). I am exporting several clips and scrolling down through the myriad of codecs each time to get to the Uncompressed 8 bit NTSC option.
Does anyone know if there a setting to ask FCP to pre-select a clips native codec for export?
Scott Skaja
edit/design/animation
http://www.scottskaja.comRafael Amador replied 18 years, 8 months ago 4 Members · 6 Replies -
John Pale
December 29, 2007 at 9:11 pmIf you select Export Quicktime , you don’t need to do anything at all to have the resulting file be the same format.
If you select Quicktime Conversion, then you have to specify the codec.
Scott Skaja
December 29, 2007 at 9:41 pm -
Rafael Amador
December 30, 2007 at 11:41 amDo what John says. Avoid export through QT conversion. Every time you export, your movie is recompressed, even if you export with the setting of your clips.
RafaelPPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE -
Scott Skaja
December 30, 2007 at 12:04 pmI get that. But I am prepping files for AE, pulling selects, if you will. Instead of using the entire 30 minute clip in AE and hunting and pecking there, I am exporting QT that are not self-contained, making it easier/faster to navigate in AE. So I am not recompressing.
So, back to my original question…
Is there a check box that says “Export Using Native Codec”?
(and for FCP developers who may be tuning in) if there isn’t, why not?
Scott Skaja
http://www.scottskaja.com -
Bouke Vahl
December 30, 2007 at 4:18 pmi don’t get it.
If you export by ref, there is no way your clips are recompressed, as it’s just a pointer to the orginal files.What kind of problems do you have then?
Bouke
http://www.videoToolShed.com
smart tools for video pro’s -
Rafael Amador
December 31, 2007 at 4:18 amYes Scott,
We do not understand yet how you are exporting.
If you are in FC, you have two ways to export:
a) QT (Export from your FC sequence).
b) QT conversion.If you are using the QT option, you can export:
1) Reference movie. When you uncheck “Make movie Self-contained”. This is not a real movie, but a document that points to the original clips, or the FC rendered files.
2) Self-contained movie This is a full movie. The codex will be the same of the FC sequence, unless you change “Current setting”.If you are exporting with QT conversion you can not export reference movies. Only self-contained. And anyway the movie will be re-compressed. Even if you are exporting with the same setting of your original footage.
If you just want to export references movies to AE, can be even easier with the QT player than with FC.
Do like that:
– Open your footage with QT player.
– Select the shot you want (this you hav to do it with two small things(?) that you find in the QT player time-line. Under the play-head) .
– Comm-C to copy the shot.
– Comm-N to open a new QT window.
– Comm-V to paste the shot in the new window.
– Now DO NOT EXPORT, but SAVE AS.
– Select: Save as a reference movie.
Now you’ve got it. Your .mov is a small doc that points to your original 8b Unc footage. Just bring it to AE.
Hope this helps.
rafaelPPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
