Activity Forums Apple Final Cut Pro Legacy Export Question
  • Export Question
    Posted by Maurik De ridder on June 19, 2009 at 10:23 am
    Hi Folks…
    I have 2 questions that I like your opinion on.
    Question #1
    I’m color correcting a show edited in FCP with the DVCPRO HD codec (720p25)
    Now I want to grade that in Color and export it to the same codec
    But the final deliverable is in SD PAL Uncompressed 10Bit
    When I sent the footage back to FCP, I’ll get a DVCPRO HD Sequence, but how do i get a SD final.
    A: by using Export>Quicktime Movie, Recent Settings, and use Compressor for the transcoding to SD Uncompressed 10Bit
    B. by changing the sequence settings to SD Uncompressed 10Bit, Render Timeline, Export>Quicktime Movie with Current Settings (and deselect Recompress All Frames)
    C. by just using Export>Quictime Movie>Setting Uncompressed 10 Bit (and select recompress all frames)
    D. I know you can do a hardware conversion but I lack the Kona 3, I do have a Decklink Mulitbridge
    Question #2
    I recently edited a show in XDCAM IMX PAL 50 Mb/s
    Also here I needed a Uncompressed 10Bit version for dump
    A. by changing Sequence Settings to Uncompressed 10Bit, Render Timeline, Export>Quicktime Movie with Current Settings (don’t select recomress all frames)
    B. by changing Sequence Settings to Uncompressed 10Bit,Do Not Render Timeline, Export>Quicktime Movie with Current Settings (select recomress all frames)
    C. by keeping the Sequence Settings to XDCAM IMX PAL 50 Mb/s, Export>Quicktime Movie> Settings set to Uncompressed 10Bit (select recompress all frames)
    I’m at least interested in the difference between A and B (rendering timeline without recompress all frames, or not rendering timeline and with recompress all frames)
    These are workflow options that I hope you can shed some light upon
    Thanx in advance…. This forum is a real lifesaver
    Maurik de Ridder
    Jaap Verdenius replied 17 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Alex Elkins
    June 19, 2009 at 1:57 pm
    [Maurik de Ridder] “Now I want to grade that in Color and export it to the same codec
    But the final deliverable is in SD PAL Uncompressed 10Bit”
    In Color you can set your project to render out as Uncompressed 10bit.
    Just to clarify, are you delivering a file, not a tape? If you were delivering a tape then most capture cards would do the down-conversion for you. They won’t help you if you’re delivering a file though.
    If you’re delivering a file, then I’d recommend doing the conversion in Compressor.
    Good luck,
    Alex Elkins
  • Jaap Verdenius
    June 19, 2009 at 8:03 pm
    I agree with Alex, Export to Compressor is the best option
  • Michael Gissing
    June 19, 2009 at 11:19 pm
    I have never been happy with letting FCP make a down conversion with any of the methods you describe, compared to a hardware down convert. I also have a Decklink card and their down convert is not good either. Kona is the best at that.
    External hardware is a better approach if you are delivering tape. Compressor is the best alternative if making a file.
  • Maurik De ridder
    June 20, 2009 at 9:12 am
    thnx for the comments
    So through compressor for the downconvert from HD to SD
    But what in the case of the XDCAM timeline (which stays in SD)???
    What is there the best method to go to Uncompressed 10Bit
    greetings Maurik de Ridder
    Freelance Editor
    MacPro 2x 2.26 GHz Quad-Core Intel Xeon, 6.0 GB RAM, ATI Radeon HD 4870, Multibridge Pro, Sonnet Fusion DX800Raid 8TB
    QT 7.6.0 FCP 6.0.5 Color 1.0.4 Compressor 3.0.5 Episode 5.1.1
  • Jaap Verdenius
    June 20, 2009 at 11:56 am
    Then you might as well stay inside FCP – Just turn the XDCAM sequence into an uncompressed 10bits sequence (choose the preset in the sequence settings) and go File > Export Quicktime Movie (selfcontained of course).
    Jaap
  • Maurik De ridder
    June 20, 2009 at 8:40 pm
    Hey Jaap…
    Okay… this is what I always do in this situation… But trying to figure out the “recompress all frames” feature.
    I always use Recompress All Frames when I’m exporting a sequence to another codec then the sequence codec
    But in this situation you change the sequence settings to another codec and then render the sequence. Do you use recompress all frames in this situation, or is it better not to.
    And what happens if you didn’t render the timeline after changing the codec to uncompressed 10Bit.
    Then I would assume you need to use Recompress All Frames …
    Still a bit confusing to me … would love to clear this up
    Thanks Jaap for taking some time
    Maurik de Ridder
    Freelance Editor
  • Jaap Verdenius
    June 20, 2009 at 11:02 pm
    To be honest I am a bit confused on this point – the manual says that “media that have to be created from scratch” (things that have to be rendered) need recompressing. But I always have this option deselected. I always render to the current settings (with or without things being rendered in the timeline) and I never noticed a problem.
    NB I forgot to mention a few things:
    – in the Video Processing tab of the Sequence settings you should switch to 10-bits processing, if you want to take advantage of those 2 extra bits.
    – what is convenient about sequences that are set to 8- or 10-bits uncompressed is that you will have more filters available in real time.
