export quality
Hi
I am having trouble with the quality of the footage i am exporting. When i go to Export – using quicktime conversion – options, i never know which compression to use under settings. Obviously i want the highest quality picture for whatever i am doing so i have tried using UNCOMPRESSED 10 bit, but this turned out to be 33 GB on a half hour long piece. The thing is the quality was beautiful and i really dont want to loose this. I have tried using some of the others but the quality isnt so good.
What i really want to know is what are all the different compression rates for, for example when shoudl you use DVCPRO 50- PAL, MPEG 4 VIDEO, H. 261 and all the other compression opions they give you. They really confuse me!
Most importantly which one should you use to get the best quality but that will also fit onto your DVD and which is compatible with i DVD.Thanks!!!
