Activity Forums Adobe Premiere Pro Export Project structure to Excel or XML (or something similar?)
  • Export Project structure to Excel or XML (or something similar?)
    Posted by Stephen Kennedy on June 24, 2012 at 5:20 pm
    I have an assistant editor working on a project, and need them to prepare footage for the edit for me.
    What I want is for them to subclip the footage, giving them appropriate names, and then add keyword tags in the description column of the metadata. I’ve created a super-stripped schema for the project panel, so it shows only Name, Media Duration, and Description.
    I then want to find a way to export this information in a way that I can use it to build a searchable database of all the clips – so that I could search by tag in the description column, for example.
    Granted, they could just email me the PP project file itself, and I would be able to see all this information, and search it, but I would like to be able to extract it into a database so that we can have an online google doc of the footage library as we’re building it.
    Alex Udell replied 14 years, 2 months ago 2 Members · 1 Reply
