Activity Forums Adobe Premiere Pro Export problems with Premiere
  • Export problems with Premiere
    Posted by Michael Neumann on June 17, 2010 at 11:24 am
    I'm doing a video in Premiere. Since turning up detailed pictures and words. The video is about. 5 min and consumes about 1 gb and that with the result
    https://www.Foto-Upload.net / Unbenannt5qzgt630.Jpg
    What am I doing wrong? Or. How do I set it, So that the writing does not revolve around looks good?
    Thank you before for help
    Alex Band replied 16 years, 3 months ago 2 Members · 1 Reply
  • Alex Band
    June 19, 2010 at 5:01 pm
    The only thing I can think of is to check to make sure you’re exporting it in the proper definition. Where did those letters come from, an AE composition? If that’s the case, check to make sure the framerates match up from your AE composition and the Premier sequence. Also, if you’re exporting it in HD, if you’re exporting it in 1080p try 1080i instead, or vice versa. That’s about all I can think of.
