Activity Forums Apple Final Cut Pro Legacy Export Problems
  • Export Problems
    Posted by Steve C. on July 26, 2007 at 3:33 pm
    I exported my Final Cut project using Quick Time conversion and the DVCPRO50 setting and it looks great on my iMac. When I played it on my old DVD player that is hooked up to my TV it looks good but jumps quite a bit. Any other settings that I can try to get good quality but no jumping? Thanks.
    Steve C. replied 19 years, 1 month ago 2 Members · 4 Replies
  • 13 Create COW Profile Image
    13
    July 26, 2007 at 5:26 pm
    [Steve C.] “Any other settings that I can try to get good quality but no jumping?”
    Well if we know what settings you used, then we might be able to suggest “other settings”
    What did you use to burn the DVD?
    What where your compression settings.
    You say you are plying it on a old DVD player, douse it look the same on other DVD players?
  • Steve C.
    July 26, 2007 at 5:56 pm
    I exported it using the DVCPRO50 setting in Quick Time conversion. Then I burned the DVD using Toast 8 Titanium. I haven’t tried it on a newer DVD player yet but it looks great on my laptop (Powerbook G4) player and my iMac. I’m looking for another setting in Quick Time to use.
    13
    July 26, 2007 at 6:48 pm
    its not going to be a quicktime setting, Toast or any other DVD program the douse the encoding for you will take whatever quicktime you give it and reincode it, usually using there own settings that you have little or no control over. That is why I NEVER use them, I want the control, so I encode the file myself and then make the disk in DVD SP
  • Steve C.
    July 30, 2007 at 3:41 pm
    Thanks for the info.
