Activity Forums Apple Final Cut Pro Legacy Export problems
  • Export problems
    Posted by Sarza on October 28, 2005 at 5:12 am
    Hi
    I am creating a DVD and all was going well. I exported each sequence using Quicktime Movie… with Make Movie Self-Contained un-checked. Imported each QT movie into iDVD and burnt the DVD. I watched it on a TV and noticed a couple of things I wanted to change. I went back into FCP and made my changes – nothing major. Now when I try to export the two sequences that I’ve edited, using the exact same method, they each take a couple of hours to export. Before they only took a few minutes. My main problem is that I have limited space on my hard drive and run out of room just before the second edited sequence finishes exporting.
    The first time I exported everything successfully and still had plenty of disk space to burn the DVD and now there’s no way. They seem to exporting slowly and as much larger files. I deleted the original exported movies. The changes I made to the sequences were only to re-size the wireframe in a couple of scenes.
    I hope this all makes sense. Any help would be greatly appreciated – I need to post this DVD out tonight!!
    Don Greening replied 20 years, 11 months ago 2 Members · 1 Reply
  • Don Greening
    October 28, 2005 at 7:11 am
    Try trashing your FCP preference files, restart FCP and then export your QT movies again. If you’re unsure how to do this here’s a link on how to do it the right way:
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    There’s also a freeware program available that does it for you called FCP Rescue. Just Google it and it’ll come up.
    – Don
