Activity Forums Apple Final Cut Pro Legacy :export problems
  • :export problems
    Posted by Steve Foulkrod on November 3, 2010 at 12:29 am
    Hello,
    I having a bit of trouble exporting a 60 sec spot I cut for a client. After following all of Google’s guidelines they keep telling me the bitrate is too low. They require 6Mbps & I’m restricting my data rate to 6000 kbps as they advised. See my export, sequence settings(DV NTSC 48khz)below. Btw, I’m using FCP 5.0 without compressor.
    Steve
    Movie Settings: H.264 Quality:High Frame Rate:29.97 Bitrate 6000 kbits/sec
    Frame reordering: Yes Encoding Mode: multi-pass Dimensions: 720×480 (640×480)
    Audio: Integer (Big Endian) Sample Rate: 48.000 khz Sample Size: 16bit
    Channels: Stereo L/R
    Google TV Guidelines
    Video:
    Resolution:
    * 720 x 480 @ 29.97fps (NTSC)
    * frame aspect ratio: 4:3
    * pixel aspect ratio: 0.9
    Upper/Top/Odd field first
    Codec: AVC H.264 (Main Profile 3.0), MPEG-2 (Main Profile @ Main Level), Uncompressed/RAW (except V210/10-bit), DVVIDEO
    Bitrate: At least 6Mbps (CBR).
    Luma should occupy full spectrum between NTSC standard 7.5 IRE black and white level at 100 IRE
    1. of frames for NTSC format
    15 sec ad: 450 frames
    30 sec ad: 900 frames
    45 sec ad: 1350 frames
    60 sec ad: 1800 frames
    75 sec ad: 2250 frames
    90 sec ad: 2700 frames
    120 sec ad: 3600 frames
    Text overlays should be title-safe
    Audio:
    Samples: 48Khz, 16bits
    Dynamic Range: no greater than 7dB
    Codec: MPEG1-Layer 2, AAC, PCM
    Bitrate: At least 256kbps
    Number of channels: 2 (stereo)
    Michael Gissing replied 15 years, 10 months ago 3 Members · 5 Replies
  • Michael Gissing
    November 3, 2010 at 1:16 am
    If you use multi pass variable bit rate, the data rate will be below 6Mbps. The google specs says 6Mbps CBR which means constant bit rate. Nothing wrong with using VBR but increase the maximum so that the average is around 6Mbps.
    Also the audio specs are asking for mpeg audio, not uncompressed which is what you are using. Without Compressor and using an old version of FCP, you may not be able to do that. It may not matter, but I am noting differences between the spec and your settings.
  • Steve Foulkrod
    November 3, 2010 at 1:23 am
    Michael,
    Thanks for the quick response. Yeah, I thought I might run into trouble using an older ver (FCP 5.0 Academic). Compressor will not install correctly. I keep getting the “unable to connect to background process” error. I’ve tried a few posted fixes & no dice. I’ve tried bumping up the data rate, but still get a rate of 5.50mbps. I’ll re-examine the audio. Very frustrating.
    Steve
  • Kylee Pena
    November 3, 2010 at 1:02 pm
    Also, it doesn’t say it on their list of guidelines but when you look more closely at their FCP tutorial, there are some networks that require 12 mbps to air.
  • Steve Foulkrod
    November 3, 2010 at 1:09 pm
    Thanks, you guys are awesome! I had posted this same problem on the Apple discussion boards days ago with no responses. Yeah, I had read through their guidelines & saw that they like to see files closer to 12mbps, but minimum of 6mbps. So, I spit out a file that was over 10mbps & I’m currently awaiting approval. Btw, do you guys know of a way to get Compressor work on a G5 machine using FCP 5.0 Academic?
    Steve
  • Michael Gissing
    November 3, 2010 at 9:21 pm
    Compressor is part of the Final Cut Suite. Time to upgrade from version 5 which is pre the suite and also discover the wonders of Motion.
