Activity › Forums › Adobe After Effects › Export Problem
  • Export Problem
    Posted by Ben Mullins on October 23, 2009 at 12:55 pm
    Whenever I render out a composition from AE 8.0 (MAC) the resulting Quicktime is always much darker than the original footage. I never apply any colour grade or effects which might do this so I was wondering if this is a settings-based issue. The footage I bring in is either uncompressed QT or ProRes HQ, but either way the result is always the same. I have tried different codec settings upon export but to no avail. If someone could suggest a solution I would be most appreciate.
    Thanks in advance,
    Ben.
    Todd Kopriva replied 16 years, 11 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    October 23, 2009 at 1:32 pm
    AE works in RGB. Perhaps your source is YUV or your CODEC works in YUV space. You’ll have to tweak it in your editing app or in AE. The good thing is that you can save the setting (Levels should do the trick) as an Animation Preset.
    HTH
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
  • Todd Kopriva
    October 23, 2009 at 2:12 pm
    There are some well-known issues with gamma in QuickTime Player. See this page for more information.
    For ProRes footage specifically, see this post.
    As with all such questions about getting consistent color, the first answer, though, is that you should use color management.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
