Activity Forums Apple Final Cut Pro Legacy Export problem-its only exporting a portion of my sequence
  • Export problem-its only exporting a portion of my sequence
    Posted by Jason Cox on July 1, 2010 at 9:55 pm
    So I’m editing a project with a 1920×1080, 23.98, prores (HQ). I shot on a canon 7d with some 60fps footage which has also been converted to prores and 23.98. It all looks good in the timeline and plays well there, but when I export it only exports my titles and the first clip, the beginning 14 seconds of my two minute clip. This is not a trial version of fcp and nothing is selected in the timeline and no in and out points are in. Any ideas?
    Jason Cox replied 16 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • William Carr
    July 2, 2010 at 12:30 am
    Sure everything is the absolutely same codec and it matches the sequence setting?
    Anyway, force a full render everything in the sequence.
    If no go, trash prefs, etc.
  • Jason Cox
    July 2, 2010 at 3:11 am
    the all have the same codec, but yeah I have different settings on certain clips. The sequence is 1920×1080, 23.98. I have footage at 1920×1080, 1280×720 at 23.98 and 1920×1080 at 59.94
  • William Carr
    July 2, 2010 at 7:12 am
    So fully rendering it all in the sequence didn’t work? Convert all clips at least to the same frame rate, if not the same dimension. Use those clips in the sequence instead of the originals.
  • Jason Cox
    July 2, 2010 at 9:44 pm
    I did the render all, both. Still nothing. The first three clips in the timeline are all the same codec, dimension and speed, but it still only does my two titles and the first clip.
  • William Carr
    July 2, 2010 at 10:43 pm
    If it’s stopping on that same clip maybe it’s corrupt. Can you render or export the clips after it?
  • Jason Cox
    July 7, 2010 at 1:52 am
    Hey thanks man, that worked. I appreciate the walk through. Now I just need to figure out what I should export all that shit at so I can put it on the net. Any ideas?
  • Jason Cox
    July 7, 2010 at 2:53 am
    Hey thanks man, that worked. Thanks for all the help
