Activity › Forums › Apple Motion › Export problem. Can’t see comp…
  • Export problem. Can’t see comp…
    Posted by Christopher Travis on October 4, 2013 at 4:21 pm
    Hello all,
    A colleague and I are both using Motion 4 to do some chroma keying but for some reason when my colleague tries to export his comp, all that comes out is the white background. The comp looks fine in the canvas/viewer in motion. I’m exporting with no problems on my computer. Since the comp looks fine in the canvas, something tells me this is an incorrect setting somewhere in the export/preferences window but I’ve checked them and nothing is standing out to me. Can anyone shed some light on this? I think/hope this is probably quite a simple fix.
    Chris
    Christopher Travis replied 12 years, 12 months ago 3 Members · 4 Replies
  • Tim Jones
    October 4, 2013 at 5:20 pm
    A shot in the dark here, but I had some export issues with Motion a while back and reinstalling Quicktime solved them.
    HTH
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Andy Neil
    October 4, 2013 at 5:23 pm
    In Motion 4 it’s possible to output the Alpha only which, if there’s no transparency in your project, will appear as a white QT. I’d check the advanced options in the export dialogue to see if that’s the case.
    Andy
    https://www.timesavertutorials.com
  • Christopher Travis
    October 4, 2013 at 5:26 pm
    Update: I gave my colleague a project file of mine that had worked, and he was able to replace the footage and export successfully.
    We can get by from here using this project setup but out of curiosity id still like to hear some thoughts. I guess it’s not an export setting since the last one worked. Can anyone think of a reason why one would get a blank export when the comp looks fine in the canvas?
    October 4, 2013 at 5:28 pm
    That sounds promising Andy. I’ll check it on Monday.
