Activity Forums Apple Final Cut Pro Legacy export problem
  • Posted by Pepijn Klijs on December 18, 2010 at 2:34 pm
    I am having a very strange problem.
    I am working on a project in FCP and Color, all canon footage converted to pro res 422. Everything is running smooth untill I want to export to quicktime. When reviewing the quicktime on my desktop with quicktime player 7.XXX I immediately notice a big change in the contrast and saturation. To show you more clearily what I mean I included an image grab from my screen with both the fcp canvas window and a exported still visible.
    Do you know what could cause this big difference? One of the things I tested was importing the quicktime movie I exported back into FCP. Result: NO CHANGE in saturation and contrast at all! But my clients will be watching this on Vimeo etc and not next to me in the edit room so I still have a problem since the export doesn’t look the same in quicktime player.
    Any clues?
    Avid/FCP Editor, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
    Pepijn Klijs replied 15 years, 8 months ago 3 Members · 4 Replies
  • Jerry Alto
    December 18, 2010 at 8:25 pm
    Pepijn- Sounds like you might have a gamma correction issue between FCP and quicktime. Launch FCP, go the help menu and search gamma. Also check Vimeo’s suggestions on gamma.
    HTH,
    Jerry
    MacPro 2.93 Quad
    FCP7
    Sony Z-1
    GV-HD700
  • Richard Keating
    December 18, 2010 at 9:05 pm
    This “Gamma Shift” issue with Quicktime is a common problem. Do a search for “gamma shift and quicktime” and you’ll see lots of discussion on the topic. I came across a tutorial on how to fix this a while back which I didn’t try but may be worth looking at:
    https://www.videocopilot.net/blog/2008/06/fix-quicktime-gamma-shift/
    Richard Keating
    Editor, Co-Creator of ScreenLight
    “Centralized Video Project Collaboration”
    http://www.screenlight.tv
    Blog: blog.screenlight.tv
  • Pepijn Klijs
    December 18, 2010 at 9:42 pm
    Thanks for your reply!
    On vimeo.com their is no help available on gamma issues.
    Yes, searching for ‘gamma’ in the FCP help menu gives a lot of hits, but maybe a bit too much cause I can’t find my problem there.
  • Pepijn Klijs
    December 18, 2010 at 9:44 pm
    It’s strange. Most the people talk about washed out contrast, while my problem is the opposite, my exports have too much contrast and too much saturation.
    I tried it, but it didn’t work.
    Thanks for your reply anyway!
