Export Problem
Hey guys,
Want to export a 720p24 uncompressed 8-bit movie from FCP. Wanted to use the “Export To Quicktime” so that it would not get recompressed. This is my first time on FCP 6 and things are a little different. The other thing is that I usually work on a machine with either a Kona or Decklink card which have their own Easy Setups. I downloaded the Kona codecs, but still don’t have the option to export a 720p24 8-bit movie without having to create a custom setup. I don’t even see any Kona options in the Export to Quicktime or Easy Setup. Do I need to download the drivers too to see these options? If I just create a custom setup with all the right settings, will that basically just be the same as if Aja had done it for their setups?
Best,
Eli
