Activity Forums Apple Motion export problem
  • export problem
    Posted by Gary Woloszyn on January 21, 2008 at 5:17 pm
    I exported a Motion project to a QT file for a client in the DV format and they are unable to open it. I know they have an older version of FCP and QT so is there a way I can save it differently, maybe in Compressor?
    I am using FCP 6.0.2 and QT 7.3.1.
    Thanks…
    Gary Woloszyn replied 18 years, 8 months ago 2 Members · 2 Replies
  • David Bogie
    January 23, 2008 at 5:09 pm
    DV hasn’t changed, it is not dependent on QT or FCP versions. Most likely you exported it incorrectly, no way to tell from where I’m sitting. You can export with Compressor in any format you want to try but you don’t need Compressor to give them DV.
    bogiesan
  • Gary Woloszyn
    January 23, 2008 at 6:30 pm
    Thanks, yeah I figured the file was corrupted when uploaded to the MediaFire website for the client. I put it on disk and works fine….
