Activity Forums Adobe Premiere Pro Export Premiere 5.5 Vimeo
  • Export Premiere 5.5 Vimeo
    Posted by Art Henares on September 21, 2011 at 7:14 am
    I’m trying to export my 3 min video to vimeo using the preset vimeo HD preset but it’s not exporting it as a full frame (4:3). It looks like it’s exported in a widescreen format but the videos looks streched.
    I’ve manually set everything to 4:3; fps 23.96 and also tried to leave it alone but it doesn’t help.
    My videos are all H264 format files set at 23.96 fps
    Art Henares replied 15 years ago 2 Members · 4 Replies
  • Jeff Pulera
    September 21, 2011 at 2:44 pm
    You say you are using a Vimeo HD preset, and the thing is that HD is ALWAYS Widescreen, there is no 4:3 HD format.
    What is the source video? In the Export settings, what is the resolution and pixel aspect ratio?
    Jeff Pulera
    Safe Harbor Computers
  • Art Henares
    September 21, 2011 at 5:16 pm
    That makes sense. Thanks!!
    My export settings is at 1280×720(resolution) and 4:3 (pixel aspect ratio).
    Thanks again!!
  • Jeff Pulera
    September 21, 2011 at 5:27 pm
    Hi Art,
    You may be confusing Pixel Aspect Ratio (PAR) with the screen dimensions ratio. The PAR for 720p HD should be 1.0 (square pixels). And again, HD video is always 16:9, you can’t really set it to 4:3.
    I ask again – what is the SOURCE video that you are starting with? Is it 4:3 SD (NTSC/PAL)? If so, you’ll probably want to edit in a Widescreen SD project, so your video will have black bars at the sides (pillar boxing) and that is unavoidable, but then the source will be 16:9 and should convert to 720p with proper widescreen look without stretching (will still have pillar boxing).
    Jeff Pulera
  • Art Henares
    September 21, 2011 at 10:49 pm
    Hi Jeff,
    Thanks for all your help. Your previous explanations really helped alot. I figured out that my problem was the pixel aspect ratio. I should’ve left it alone instead of changing it to 4:3
    Art
