Activity › Forums › Apple Final Cut Pro Legacy › Export PAL for web
  • Export PAL for web
    Posted by Rob Grauert on December 16, 2008 at 4:18 pm
    At my internship I edited a video that is in the PAL format. It is ready to be exported for the web and I was wondering if there is anything I should do differently during compression than I would for NTSC video.
    For NTSC I normally export a progressive video at 30fps with a resolution of 320X240 or 640X480. Are these OK for PAL?
    Also, my supervisor wants it exported as 320X480. Is that right? It sounds weird to me, but maybe it’s because is PAL.
    Thanks for your help.
    Robert J. Grauert, Jr.
    Rafael Amador replied 17 years, 9 months ago 3 Members · 2 Replies
  • Michael Gissing
    December 16, 2008 at 9:24 pm
    The only difference is frame rate and pixel resolution. PAL is 720 x 576 @ 25 frames per sec. Scale accordingly at that frame rate. Done
  • Rafael Amador
    December 17, 2008 at 2:14 am
    [Rob Grauert] “For NTSC I normally export a progressive video at 30fps with a resolution of 320X240 or 640X480. Are these OK for PAL? “
    Those sizes are correct the same for NTSC than for PAL when you go 4×3 in square pixels.
    [Rob Grauert] “Also, my supervisor wants it exported as 320X480. Is that right? It sounds weird to me, but maybe it’s because is PAL. “
    No sense.
    Don’t forget to de-interlace.
    Rafael
    http://www.nagavideo.com
