Activity › Forums › Adobe After Effects › Export or pre render- and another question
Posted by Joseph Wu on December 9, 2010 at 5:18 amWhat is the difference between exporting and pre-rendering?
also, how do i export a section of the timeline?
thank YouAdam Chesbrough replied 15 years, 7 months ago 3 Members · 3 Replies -
Michael Szalapski
December 9, 2010 at 3:34 pm“What is the difference between exporting and pre-rendering?”
Exporting in AE is rendering. So there is really no difference. Prerendering is simply rendering a lossless file and replacing the item in the AE timeline with the rendered file.
“also, how do i export a section of the timeline?”
Set your work area to the section you want to render and make sure in your render settings that you have it set to render work area only.
You seem rather new to AE. Welcome! I highly suggest you check out these (free!) resources. They’ll cover a lot of these basics for you and give you a great foundation which will help remove a lot of the frustration from using After Effects.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Adam Chesbrough
February 4, 2011 at 4:12 pmI want to export four seperate clips on the same timeline via the render que. I move the in out section over those clips and add to render que, make sure that the setting is “work area only” but all that is rendered is where the in/out section is currently placed within the composition (hope this makes sense). I am definitely doing something simple incorrectly. Any advice? Thanks
macbook pro 17″ i7, 8GB RAM
esata external HD 7200RPM
canon 5D mark II, 24-70mm, 50mm, 15mm fisheye, juicedink DT454, zacuto striker -
Adam Chesbrough
February 4, 2011 at 4:31 pmThanks, thought there might have been a solution on a single timeline, oh well.
