Activity Forums Boris FX Particle Illusion Export Options or SDK?
  • Export Options or SDK?
    Posted by Kevin Bass on September 19, 2011 at 9:20 pm
    Hello,
    I am sure I probably already know the answer to this question as you would more than likely include this information on your product features but I will ask anyway. Is there a way to do any of the following with Particle Illusion:
    – Export the data for effects a user makes in some generic format such as XML, Text, etc.?
    – Do you have an API/SDK available to allow third partys to load/decode .IP3 files?
    – If no to both above is it possible to get the file format so that one could decode the file?
    I would like to use your software to create particle effects but would like to use them in my own software/rendering engine. Is there anyway to use this in my own applications instead of using a sprite sheet or avi?
    Thanks.
    Kevin Bass replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
