Activity › Forums › Avid Media Composer › Export of multi-grouped XDCamHD footage
  • Export of multi-grouped XDCamHD footage
    Posted by David Koch on May 2, 2012 at 8:58 am
    Hello,
    i am working XDCam HD Files via AMA-link in AVID MC 5.5. It is a multigroup sequence.
    It becomes a problem when trying to export it: “It’s not possbile because you cannot export a sequence linked via AMA”. So i right-mouse-clicked the sequence and transcoded it to the internal DNXHD encoded .mxf files. But it still didn’t work. After a Video Mixdown it was successful.
    Is there an easier way to export a sequence, for example “same as source” ? Especially when you work in a multigroup: It seems that AVID has got some problems transcoding the files included in a group. Is there a way to convert a multigroup sequence into a standard sequence?
    Cheers,
    David
    Brendan Maghran replied 14 years, 5 months ago 2 Members · 1 Reply
  • Brendan Maghran
    May 2, 2012 at 8:42 pm
    Try “commit multicam edits” before transcoding the sequence.
