Activity Forums Apple Final Cut Pro Legacy export of HD footage results in 4:3 ratio instead of 16:9
  • export of HD footage results in 4:3 ratio instead of 16:9
    Posted by Arturo Marroquin on October 16, 2008 at 10:42 pm
    hi guys,
    I’m working on a doc shot in 1080i and when I export the trailer for web it results in 4:3 aspect ratio instead of 16:9. What is the best codec to use for 1080i in order to preserve the aspect ration and shrink the size down for web? thanks guys . . .
    -Arturo
    Arturo Marroquin replied 17 years, 11 months ago 2 Members · 6 Replies
  • Bill Dewald
    October 16, 2008 at 11:12 pm
    Its not a matter of codec, its a matter of aspect ratio/ frame size.
    How are you exporting your timeline? Compressor? Quicktime Conversion?
    Quicktime Conversion defaults to a 4:3 frame. Use a custom size such as 320×180 in order to get a 16:9 frame.
  • Arturo Marroquin
    October 16, 2008 at 11:16 pm
    Thanks for the quick reply Bill–I’ve been using quicktime conversion. Do you recommend Compressor instead?
    -Arturo
  • Bill Dewald
    October 16, 2008 at 11:25 pm
    Compressor will give you better control over your export settings, and has the added bonus of not tying up your Final Cut app while it works…
    I often use Quicktime Conversion for small, quick things – but if this is going out to the public, you may want to check out Compressor, and see what it can do.
  • Arturo Marroquin
    October 16, 2008 at 11:38 pm
    Okay, thanks Bill–just one more thing: which Compressor settings would you suggest to export for webcast? (I’d like to offer both high and medium quality trailers on the site.)
    –Arturo
  • Bill Dewald
    October 16, 2008 at 11:58 pm
    K, here’s what you do:
    go to –
    https://www.apple.com/trailers/
    Pick a fave, find a size/format that you like, and then download it. Open it in Quicktime Player, and note the frame size and bit rate.
    Then do that… Or something close to it. Compression is an art as well as a science, so it make take a few tries. Good luck!
  • Arturo Marroquin
    October 17, 2008 at 6:21 am
    thanks!
