Activity › Forums › Apple Final Cut Pro Legacy › Export Mystery
  • Posted by Pepijn Klijs on September 23, 2010 at 6:15 pm
    I have the following weird thing happening on my FCP system:
    As I finish my edit and export to quicktime, the quicktime movie exported scales down a few percent just before almost every cut.
    When I select the “recompress frames” option, it solves the problem, but takes a long time export.
    My footage was shot on a canon 550d and transcoded to prores 422. I also used Apple Color to grade the sequence.
    My sequence setting are:
    Has anyone ever had the same problem? I wonder what causes this.
    Avid/FCP Editor, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
    Jeremy Garchow replied 16 years ago 6 Members · 12 Replies
  • 12 Replies
  • Jerry Hofmann
    September 23, 2010 at 6:42 pm
    What settings are you using when you select the QT movie export exactly?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Pepijn Klijs
    September 23, 2010 at 6:53 pm
    I’m using the “current settings”, in other words my timeline settings, of which I post a picture in my previous thread.
    Also I select the ‘make movie self contained’.
    UPDATE: When I play the same file in an older version of quicktime, so not quicktime X, the problem disappears as well!
    You think it’s the Quicktime X app messing it up?
  • Shane Ross
    September 23, 2010 at 7:16 pm
    Quicktime X is not ready for primetime. It is the last thing to be relied upon. STill a beta app, if not ALPHA.
    Shane
  • Pepijn Klijs
    September 23, 2010 at 7:34 pm
    Yeah I guess you’re right! Will not use it again anymore. Thanks.
  • John Pale
    September 23, 2010 at 7:48 pm
    I’ve seen that intermittently in Quicktime X. You aren’t doing anything wrong.
    You might try messing with the aperture settings in Quicktime Player 7.x. I haven’t had the time or patience, but it might solve it.
  • Jeremy Garchow
    September 23, 2010 at 8:54 pm
    is your timeline fully rendered before exporting? that includes checking the ‘full’ options under the sequence > render all menu and sequence > render selection menus.
    Jeremy
  • John Pale
    September 23, 2010 at 9:47 pm
    Jeremy,
    I don’t mean to speak for Pepijn, but I’ve seen it on fully rendered ProRes timelines exported as self contained Quicktimes (same as source). Only occurs in the Quicktime X player, not the Quicktime 7.x player. Its intermittent and difficult to diagnose.
    J
  • Pepijn Klijs
    September 23, 2010 at 9:55 pm
    Yep, John is right. I did fully render the timeline. It plays very well in quicktime 7. Quicktime X is the issue here. Bad product!
  • Jeremy Garchow
    September 23, 2010 at 11:21 pm
    Well that sucks. I guess that’s why I subconsciously don’t use QTX. 😉
  • Rafael Amador
    September 24, 2010 at 1:51 am
    Have a look again to the sequence setting.
    You sequence has Upper First field order.
    I guess that, being your stuff Progressive. its should be NONE.
    Rafael
    http://www.nagavideo.com
