Activity Forums Apple Final Cut Pro Legacy Export Multitrack Audio?
  • David Roth weiss
    April 14, 2006 at 4:11 pm
    Don’t know what program you’re using on the PC side, but more than likely you should simply export indivdual stereo AIFFs of all your tracks.
    You can either put a sync pop on all tracks at the same place, or even simpler, simply make certain that you export each track starting from the same precise timecode on your timeline, such as 01:00:00:00, so that you know exactly how to all tracks with picture in your app on the PC.
    DRW
