Activity Forums Adobe Premiere Pro Export multiple clips from TL
  • Export multiple clips from TL
    Posted by Christopher Loehrer on June 18, 2008 at 3:04 pm
    I have alot of projects where i shoot 1+ hours of footage. I need to break that footage up into 40 – 80 pieces (individual AVIs). I go through and Splice where i need the breaks to be.
    Currently I have to move the “Work Area Bar” over each clip in the timeline and export each individauly.
    This of course takes time.
    I would like to be able to get all the individual clips out with one process. I do not care how they are named. Just that i have individual AVI files that i can then compress to FLVs in Squeeze.
    Any ideas?
    Chris
    Jon Barrie replied 18 years, 3 months ago 3 Members · 2 Replies
  • Harm Millaard
    June 18, 2008 at 5:03 pm
    Scene detection during capture?
    Harm Millaard
  • Jon Barrie
    June 19, 2008 at 1:49 am
    I would suggest you use AE to setup the clips you’ve cut as single clips into seperated COMPS and use the Render Cueue with a preset for FLV that is set as the default. Set up one and have the where its saving to done, then select the remainder Comps (I’d put them into a Folder) drag them into the Render Cueue. Render Overnight. Each with have an assigned name based on the Comp name.
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
