Activity › Forums › Adobe Premiere Pro › Export multiple clips from timeline?
  • Export multiple clips from timeline?
    Posted by Jeremy Peplow on April 5, 2010 at 2:55 pm
    Hi All,
    Can someone tell me if this is possible in CS4?
    I have one long clip that I took a bunch of snippets of and laid them out on timeline. I now want to use project manager to create a trimmed project where allt hose clips will be seperate from the main clip. Is this possible?
    I use to do it in an old version of PP. It was a fast way to export a bunch of b-roll from one long capture. I would do it in project manager but now when I use project manager it seems to want to just copy over the one long clip to a new trimmed project.
    I know I can make each clip a sub-clip. Make them all offline and then re-capture. Just way too time consuming.
    Any thoughts?
    Vince Becquiot replied 16 years, 5 months ago 2 Members · 2 Replies
  • Vince Becquiot
    April 5, 2010 at 3:45 pm
    Hi Jeremy ,
    Yes, go to project > Project manager.
    New trimmed project should be selected, exclude unused clips. Select a path away from your current project folder. I would leave at least a 60 frame handle for minor cut adjustments in the future.
    Than should be it.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Vince Becquiot
    April 5, 2010 at 3:59 pm
    Thinking a bit more about it, I guess you mean that you cut those in sequential order keeping the original insert intact, so Premiere just keeps it as a single file.
    With subclips, remember that you can convert to “master clip” by right clicking > Edit subclip. You still have to do this for each instance.
    It would go fairly fast using keyboard shortcuts, but no magic wand.
    Vince Becquiot
    Kaptis Studios
