Activity Forums Avid Media Composer Export MPEG Error Message
  • Export MPEG Error Message
    Posted by Melvin Royster on January 11, 2006 at 10:31 pm
    Hello girls and gals, I haven’t had the opportunity to post in here in a long time, so I guess thats a good thing. But now I’ve ran in to a problem that I’ve tried trouble shooting.
    Ok, in the past I had to export the project out as a Quicktime file, then import it into my Adobe Premiere, render it, then export it out as a MPEG there, then import it out to Adobe Encore to burn a DVD. The quicktime file in Avid seemed to be the easiest, but I wanted to try exporting out as a MPEG from Avid.
    I tried all the Codecs, but nothing has worked so far. The best picture I received was using the Full Uncompressed codec. But it won’t allow me to complete the file. An error message pops up that reads: Exception: Maximum size of AVI file has been reached. File may not be complete.
    I have the Avid Express 4.6 on a PC. External hard drive, and 1 GB RAM.
    Please help.
    Melvin
    Melvin Royster replied 20 years, 7 months ago 2 Members · 5 Replies
  • Jon Zanone
    January 11, 2006 at 11:12 pm
    Melvin –
    We tried that for a while, but we found a conflict with Premiere and the newer version of QT. Now, we export a QT reference into Sorenson, and burn it using Reel DVD. We don’t author, just first play stuff.
    I’ve never liked the way Avid exports anything other than QT. I don’t even bother trying. The reference file is small and uses the original OMFI file as a reference.
  • Jon Zanone
    January 11, 2006 at 11:15 pm
    Here’s a great (link https://www.videoguys.com/XDVtips.html#squeeze) from the Avid forums that has excellent starting points on getting from one to the other…
    Jon
  • Melvin Royster
    January 11, 2006 at 11:19 pm
    Thanks. Yeah Quicktime is the only one that doesn’t disturb the picture. What QT Reference settings do you use? And what settings do you use in Sorenson?
    Melvin
  • Jon Zanone
    January 12, 2006 at 12:19 pm
    Check out that link I posted. It has all the settings, step by step. Just remember, those are starting points. You’ll need to do a couple of tests to zero in on what works best with your process.
    HAVE FUN!
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Melvin Royster
    January 12, 2006 at 5:18 pm
    Thanks, it works, I appreciate it. This process is much easier.
    Melvin
