Activity Forums Apple Final Cut Pro Legacy Export MPEG 2 with MPEG 1 Audio in one file
  • Export MPEG 2 with MPEG 1 Audio in one file
    Posted by Randy Van patten on May 11, 2007 at 3:09 pm
    I am trying to convert some 30 second commercials to MPEG 2 with an MPEG 1 layer all in file. I have tried using Commpresor, Quicktime Conversion as well as Cleaner 6. Everytime option I try is giving me a seperate file for audio.
    I am converting these for a tapeless delivery system for our cable operation that requires 1 file.
    If anyone can please give me some direction I would appriciate it. Thanks, Randy
    Rafael Amador replied 19 years, 3 months ago 2 Members · 1 Reply
  • Rafael Amador
    May 12, 2007 at 6:06 am
    Hi Randy,
    You can mux these files with ffmpgx but you can do it directly in Compressor too. Open a MPG2 preset in the inspector and click the “Extras” tab. You will find a check box that writes: Multiplexed MPG-1/Layer 2 Audio. Just check it and you will get a full muxed MPG2 with the video and audio in a file as you want.
    Cheers,
    rafael
