Activity › Forums › Apple Final Cut Pro Legacy › Export MPEG-2 using Compressor
  • Export MPEG-2 using Compressor
    Posted by Tom Brooks on October 13, 2006 at 1:51 pm
    When I attempt to export MPEG-2 directly from FCP (Export using Compressor), the encode takes forever. The beachball was coming up every five seconds or so. This is with an UC-8bit 29.97 SD project of about 7 minutes in length. Export setting is Apple Best Quality 90 min (2-pass VBR, everything at default settings).
    Any idea why the slowdown on the direct export method? As a workaround, exporting a QT movie with DVDSP markers, self-contained and then compressing outside of FCP in Compressor is very quick. Thx.
    Final Cut Studio, FCP 5.2.1, After Effects 6.5 Pro, Quicktime 7, G5 Quad 2.5, Kona-LHe V3, 4.5GB RAM, Nvidia GeForce 7800-GT, G-RAID 2x1TB FW800.
    Tom Brooks replied 19 years, 11 months ago 3 Members · 4 Replies
  • Bret Williams
    October 13, 2006 at 2:36 pm
    Pretty sure you don’t have FCP 5.2.1 or am I that behind?
  • Tom Brooks
    October 13, 2006 at 5:21 pm
    Thanks for the proofreading.
    Final Cut Studio, FCP 5.1.2, After Effects 6.5 Pro, Quicktime 7.1.3, G5 Quad 2.5, Kona-LHe V3, 4.5GB RAM, Nvidia GeForce 7800-GT, G-RAID 2x1TB FW800.
  • John Pale
    October 15, 2006 at 4:14 pm
    [Tom Brooks] “Any idea why the slowdown on the direct export method? As a workaround, exporting a QT movie with DVDSP markers, self-contained and then compressing outside of FCP in Compressor is very quick. Thx.”
    The slowdown is because all effects re-render directly to MPEG2 (and not the codec of the timeline). This can make for a cleaner encode (but in many cases the effect is not really noticable), but it takes much much longer.
    I usually go the reference movie route.
  • Tom Brooks
    October 17, 2006 at 3:41 pm
    John,
    OK. That makes perfect sense. So, if there were a few big renders near the beginning of the program, I’d see a huge estimated time for the encode and I could expect that to ramp down if fewer renders followed. Thank you.
    -Tom
