Export mp4 with h264 codec and mp3 audio
Hi there,
my client requested a video with the following specs.
The Video should run on an AdServer.Fileformat: mp4
Codec: vp6/h264
bitrate: 750 kbps- 1 MbpsAudio: Mpeg Layer 3
Bitrate: 128 kbps
SR: 44.1 KhzI did a lot Videos the last years but i always used the AAC Audio Codec.
I thought it wouldn´t be a problem to simple use mp3 istead but after some research i didn´t found a solution for this problem.How to Convert a Video with this audio spec´s?
There is no Option in Media Encoder and also with MPEG Streamclip i wasn´t able to get that solved.
Any Ideas?
