Activity Forums Media 100 Export Movie
  • Export Movie
    Posted by Frederic Lumiere on May 31, 2007 at 5:43 pm
    What option in Media 100 is the equivalent of FCP’s Export Movie where it keeps the codec intact and simply assembles the cut in a quicktime movie?
    Thank you,
    F
    Frederic Lumiere replied 19 years, 3 months ago 3 Members · 3 Replies
  • Arthur Dent
    May 31, 2007 at 6:25 pm
    export from edit suite as ‘self contained’
    hth
    A.D.
  • Paul Crowe
    June 1, 2007 at 5:41 am
    might be stating the obvious here… but also be aware of the settings for ‘program”frame’ and ‘range’ in the export box.
    Program exports the whole program, the frame a frame and you’ll need to set your in and out range points using F1 & F2 (using function key also on a lappy) to export a specific part of your program.
  • Frederic Lumiere
    June 1, 2007 at 1:16 pm
    Works perfectly, thank you!
    Codec is intact.
    F
