Activity › Forums › Adobe Premiere Pro › “export movie” ,,, why such huge files???
  • “export movie” ,,, why such huge files???
    Posted by Joe Garcia on September 27, 2008 at 2:16 pm
    So,,, I guess I should know this but, what the heck is Premiere doing on export that requires such HUGE files???
    I normally edit to a couple of sequences, with very few or no chapters at all, I export those sequences with little to no compression at all to allow DVD aps to do the compressing at burn time.
    So why does Premiere take 6 gigs or so with very little in the way of color correction, and a few crossfade transitions and render it to the tune of 60 to 70 gigs ????
    What’s going on under the hood ???
    thnx
    joe
    JOE
    X-Porter
    Gen 1:1
    Chet Wesley replied 17 years, 10 months ago 3 Members · 3 Replies
  • Eddie Lotter
    September 27, 2008 at 3:00 pm
    Less compression means larger files. That’s just the way that it is.
    Disk space being so cheap I prefer to work with the large files to retain maximum quality until encoding to the final delivery format.
    Cheers
    Eddie
  • Joe Garcia
    September 27, 2008 at 4:03 pm
    Ditto,,, that’s my excuse and I’m stickin to it,,,
    just had to ask cause doing the math the end result is over ten times the original
    wish I could find a bank that would do that….
    joe
    JOE
    X-Porter
    Gen 1:1
  • Chet Wesley
    November 14, 2008 at 7:16 am
    It shouldn’t matter if you have effects or not, the resulting file size is just a result of the length of the file and the bit rate.
