Activity › Forums › Adobe Premiere Pro › Export movie quality poor
Posted by Rey Candel on September 18, 2008 at 8:15 amHello everybody. Newbie here. I just completed my first 20 minute birthday video for a relative with great disappointment.
I used a canon hd camera. Picture was great while editing in premiere, but when I exported the movie and played back with windows media player the picture wasn’t even close to hd. Please help!!!! Is it something I’m doing wrong?Rey Candel replied 18 years ago 3 Members · 6 Replies -
Mike Velte
September 18, 2008 at 10:50 am[Rey Candel] “Please help!!!! Is it something I’m doing wrong?”
Dont know what you did…what were your export settings? What is the resolution of your source video? Is your export for local playback, web, DVD??
Rey Candel
September 20, 2008 at 12:31 amSorry for the lack of information and I appreciate the response.
I shot the video on a canon xh-a1 hdv 24fps. The settings I used to download into premiere(source settings) are as follows:Editing mode: hdv 1080p
Timebase: 25 frames
Frame size 1440x 1080 16:9
pixel aspect ratio: HD anamorphic 1080
Display format:25fpsI exported as follows:
Format: Mpeg-2
Preset: NTSC 23.976p Widescreen High quality
Frame rate:23.9Now I know that dvd’s arent HD quality but the resolution is blurry
and washed out. Anything I can do?? Please help. -
Harm Millaard
September 20, 2008 at 7:40 amYou shot NTSC, you edited PAL and you exported NTSC. Why? That likely is the source of your problems.
Harm Millaard
Rey Candel
September 20, 2008 at 3:22 pmHey thanks for the quick response. I m new to HD not sure what settings to use maybe that’s why I chose PAL. How do you kno if it’s a pal setting? It doesn’t say it on the load preset menu. Which setting should I use? I would greatly appreciate it. Thank you again.
Harm Millaard
September 20, 2008 at 4:12 pm24p is typically NTSC NDF, 25p is PAL and 23.97p is NTSC DF. Keep the framerate exactly as you shot with the camera, so 24p from capture to export if NTSC, and 25p if PAL. Avoid conversions.
Harm Millaard
Rey Candel
September 20, 2008 at 10:38 pmThank you so much for the info i truly appreciate you shedding light on the subject. I just found out about your website while looking for answers. You guys are great . Thanks again.
