Activity › Forums › Adobe Premiere Pro › Export movie for tv/DVD player on memory stick
  • Export movie for tv/DVD player on memory stick
    Posted by Maarten Schultheiss on January 28, 2013 at 1:13 pm
    Hello,
    I have a question how to export a movie (about 15 minutes long) to put on a memory stick so it can be put in a USB slot on a TV or DVD player.
    I tried AVI but is was bad quality and about 4GB. I like it to be around 1GB good quality.
    Is this possible and what render setting should I choose.
    Please advice.
    Maarten
    Maarten Schultheiss replied 13 years, 8 months ago 3 Members · 4 Replies
  • Jeff Pulera
    January 28, 2013 at 3:38 pm
    Hi Maarten,
    I can’t tell you exactly which format to use, as different players offer different format compatibility. Also, I don’t know what you are working with – SD, 720p, 1080?
    But in general for the newer players, H.264 should work well.
    You’ll have to experiment with YOUR gear to see what works for you
    Jeff Pulera
    Safe Harbor Computers
  • Ivan Myles
    January 28, 2013 at 5:20 pm
    I agree with Jeff; you will need to try a few different encoder settings to determine what works with your equipment. What codec did you try? Also, can you check the user manuals or call the manufacturers to get a list of compatible codecs for your TV and DVD player?
    That said, MPEG2 or MPEG2-DVD will likely work, and at SD resolution should produce a good quality video under 1GB for 15 minutes. H.264 can produce smaller files, but might not be compatible with your equipment.
  • Maarten Schultheiss
    January 29, 2013 at 8:29 am
    Thank you for your reply.
    I work with 720p. I tried a few codecs/setting but I’ll will try to use h.264 and look into what player they use.
    It’s for alot of franchise company’s so I hope they have all the same players. But any how I can explain why it would or would not work.
    Maarten.
    January 29, 2013 at 8:32 am
    Thank you for your reply,
    I tried a few settings AVI, MOV, MV2, DIVX but nothing seems to work.
    I will try this setting and otherwise look for the player they use and look up what files it can play.
    Maarten
