Activity Forums Boris FX Export Mocha tracking data in BCC 2019
  • Export Mocha tracking data in BCC 2019
    Posted by Tom Vance on January 11, 2019 at 3:03 am
    I’m having hard time finding a way to export Mocha tracking data from BCC 2019 in the OFX version. As I remember in earlier versions I could export either point tracking data or corner pin data into a file that could then be imported back into BCC manually. Is this now gone or has it been placed somewhere else?
    Tom
    Tom Vance replied 7 years, 6 months ago 2 Members · 3 Replies
  • Tom Vance
    January 23, 2019 at 1:11 am
    It seems Boris decided to remove this capability from the 2019 version. 🙁
  • Ross Shain
    January 31, 2019 at 11:32 pm
    Most Boris Continuum 2019 filters have Mocha masking embedded into the effect.
    A new feature in this version is called parameter tracking, so you do not have to import external track data, you can use the Mocha track data right in the effect.
    Hope this helps:
    https://youtu.be/n4yS56nDzok
    Ross Shain
    Boris FX / Imagineer Systems
    https://borisfx.com/products/mocha/
  • Tom Vance
    February 14, 2019 at 5:20 pm
    Ross, thanks for your reply. Yes, I understand and appreciate the new parameters built into 2019. I wish BCC would do something to defeat the need to use trackFX to use features such as cornerpin and matchmove in Vegas. Therefore, I have used the Vegasaur feature to import tracking info to apply XY to pan/crop or track motion. I can no longer do that with BCC 2019. If BCC would allow event application for Matchmove, Cornerpin it would be wonderful.
    Regards, Tom
