Activity Forums Adobe Premiere Pro Export metalogging from Premiere into a readable, printable, document?
  • Export metalogging from Premiere into a readable, printable, document?
    Posted by Griff Montgomery on August 21, 2013 at 5:05 pm
    My boss has given me the task of “Metalog this footage in Premiere. Then figure out a way to export the log into a word document you can submit to me. Then write down the process for others to use. Go.”
    I’ve searched and searched and I just can’t turn anything up. Any help out there? Can this be done?
    Angelo Lorenzo replied 13 years ago 2 Members · 1 Reply
  • Angelo Lorenzo
    August 22, 2013 at 5:10 am
    Without going into details (I have to get up early for a call time), I would think the following is a sufficient jumping off point:
    1) Log in Premiere with file link on (the little chain icon which saves metadata to your footage along with it being present in your project file)
    2) In Bridge select the file and export the metadata to an XMP file.
    3) Open XMP file in Excel or find an XML to spreadsheet converter. Metadata is stored in a very common markup language called XML, the basis for which websites are programmed.
    4) Print
    This doesn’t solve issues with file types that don’t save metadata to the file directly like R3D but should suffice for a Quicktime/MOV based workflow.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
