Activity Forums Apple Final Cut Pro Legacy Export lossless as image sequence with Compressor or Quicktime
  • Export lossless as image sequence with Compressor or Quicktime
    Posted by Phil Huizen on April 17, 2011 at 2:41 pm
    Hi there,
    I feel so smart right now cause I thought of this:
    Export my movie to still images so I can grade them in Aperture or Photoshop! But when looking on the internet nobody seems to use this technique!
    My question is, how can I export my AVCHD lite codec .mov file to lossless .PNG or .TIFF or whatever? I’ve tried using Quicktime Player 7 Pro and Compressor but it did NOT seemed lossless (while these formats support 16-bit). The brightness is off. So does somebody know a way to export LOSSLESS a .mov to image sequence?
    Thanks alot!
    Phil
    Iraklis Panagiotopoulos replied 15 years, 1 month ago 4 Members · 6 Replies
  • Chris Tompkins
    April 17, 2011 at 4:02 pm
    You shouldn’t edit in AVCHD anyways from the start.
    Convert to prores when importing.
    Edit.
    Export current settings.
    Chris Tompkins
    Video Atlanta LLC
  • Jeremy Garchow
    April 17, 2011 at 6:53 pm
    Photoshop allows QT movies. Why convert?
  • Phil Huizen
    April 18, 2011 at 3:09 pm
    Yes I’m doing that, but I’m looking for a way to convert the AVCHD to tiff WITHOUT ANY quality loss. When using QT7 Pro or Compressor I can’t seem to get identical frames when exporting to TIFF format.. Please help.
  • Phil Huizen
    April 18, 2011 at 3:10 pm
    I want to grade mostly in Aperture.
  • Phil Huizen
    April 18, 2011 at 5:07 pm
    In Photoshop I can export the movie too. When selecting JPEG LOSSLESS or Tiff, always the image is DARKER. Is this because a change of Gamma Curves OR change of Color Profile. How to avoid? Thanks!
  • Iraklis Panagiotopoulos
    August 5, 2011 at 11:28 am
    I personally use Premiere Pro and Lightroom (on a Mac) and I export TIFF image sequences. Lightroom is more appropriate than Photoshop, at least for basic color correction and for denoise purposes Lr reaches perfection. After that I just import my image sequences back to Pr Pro with no alternations or color problems.
