Activity › Forums › Adobe After Effects › Export layers from Illustrator for AE-I didnt make the logo-so kinda confused here
Posted by Matt Stoltz on September 21, 2005 at 3:02 pmhey all -i know this is a common question but i have a logo that an agency did-I see all the layers in IIIustrator but when i import the logo in AE its not coming in as layers-
the agency that created the logo had the layers in groups and stuff –layers inside of layerswhat do i have to do to get this logo into AE so I can work with each layer
thanks
matt
Banks Meador replied 14 years, 10 months ago 4 Members · 8 Replies -
Ken
September 21, 2005 at 3:44 pmFirst, be sure that the file is saved in Illustrator format. Second, in AE, import the .ai file with “Composition” in the “Import As” pull down.
Ken
Matt Stoltz
September 21, 2005 at 3:56 pmnot working ken –i resaved the EPS file as an AI file and did what you said and its still coming in as 1 layer –in the original logo in AI, all the logos objects are stacked inside of 2 other layers –do i have to do a release to layers or something?
matt
Steve Roberts
September 21, 2005 at 4:01 pmYep, there’s an Illustrator thing that requires releasing to layers, if I recall. I’m a little behind on my Illy versions, so I don’t know of an automatic way of doing it except by dragging each sub-layer (or whatever) above its, er, parent layer.
The point of this being, with recent versions of Illustrator, something often needs to be done in Illustrator before importing into AE as a composition.
Sorry I couldn’t be more helpful.
Steve
Matt Stoltz
September 21, 2005 at 4:09 pmk i figured it out –steve your idea is what you have to do–i had to drag all my sub layers (object layers) out and set those above the parent layers –i just deleated the parent layers –who needs parents haha anyway then you have to save the file as an .AI file like ken said –then import into ae as a comp
worked fine
thanks for responding guys
matt
Matt Stoltz
September 21, 2005 at 4:46 pmwell it was pretty easy –in cs2 u can select all your sub layers and pull them out –u dont have to do them 1 by 1 – once u do that it just leaves you with your parent layers –then u just delete them –took me yeah 3 steps but –hey it worked
matt
Banks Meador
November 9, 2011 at 12:39 pmThis article is old, but the solution works great.
https://illustrator.digitalmedianet.com/article/Illustrator-Objects-to-After-Effects-Layers-30923
