Activity Forums Apple Final Cut Pro Legacy EXPORT ISSUE! PLEASE HELP
  • EXPORT ISSUE! PLEASE HELP
    Posted by Phillip Crook on August 8, 2008 at 3:12 pm
    HI, I am trying to export a 31 Minute Video for my client. The problem is, when I export using Quicktime Export with Current Settings (no codecs or compression), it only exports a 58 second file. I am exporting the video at 1080i, 1920×1080. My specs are below, PLEASE HELP!! THIS IS URGENT! Thanks in advance
    PowerPC G5
    Dual Core 2.0GHZ
    2 GB RAM
    Leopard OS
    Miriam Moran replied 18 years, 1 month ago 2 Members · 1 Reply
  • Miriam Moran
    August 8, 2008 at 3:23 pm
    Couple of (generic) suggestions since I can’t see your project –
    Be sure your playhead is at the beginning of your timeline
    Be sure you don’t have an in point and out point marked in your timeline
    Try Export – Using Quick Time Conversion – and manually set your options to what you want them to be – ex. DV/DVCPRO NTSC is typically what I export – be sure you have settings that match your video
    Be sure your hard drive isn’t full
    Try using export to compressor and pick quick time as your output format
    I’m sure this is a very panic situation for you – take a deep breath, it will be ok! Good luck!
