Activity Forums Apple Motion Export is transparent
  • Export is transparent
    Posted by Bryce Douglass on July 17, 2010 at 4:20 pm
    Hello, I am trying to make a basic logo for a video and when I export it with no transparency and send it to final cut pro 7 it is transparent. It’s not supposed to be transparent. It also gives me black behind it. I have to choose composite mode screen in order to remove the black in final cut pro and this is when it becomes transparent. Is there a way to fix this?
    thanks.
    Mark Spencer replied 16 years, 2 months ago 3 Members · 3 Replies
  • Dan Johnson
    July 17, 2010 at 6:15 pm
    In order to make the export transparent export out as Quicktime Animation set to Millions Color +. Or Pro Res 444. They are the only video codecs that support transpancy.
    You can also just bring the project file direclty into Motion and it will remain transpent.
  • Bryce Douglass
    July 17, 2010 at 6:20 pm
    Did you even read what I wrote? I DON’T want it to be Transparent.
    Bryce
  • Mark Spencer
    July 17, 2010 at 7:43 pm
    Edit > Project Properties – change the Background from Transparent to Solid.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
