Activity Forums Apple Final Cut Pro Legacy Export is choppy for CC clips
  • Export is choppy for CC clips
    Posted by Grant Wilber on September 15, 2010 at 3:08 pm
    I have some video (Pro Res 422 HQ) that I’ve color corrected and have rendered everything I believe. There is a blue line above the clips that I have color corrected but I believe that just indicates the video image has been altered because it won’t render anymore.
    When I export (QT Conversion H.264, best, 720) the video I color corrected is choppy but the clips that I did nothing to playback fine. I tried exporting in pro ress too but that didn’t make a difference. Its going to be for internet and also dvd. Anyone know whats going on? Also I don’t have compressor.
    Grant Wilber replied 16 years ago 4 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    September 15, 2010 at 3:53 pm
    Select the clip and Alt-R.
    Export a Prores master and bring that to Compressor for the DVD and web video.
    Rafael
    http://www.nagavideo.com
  • Jerry Hofmann
    September 15, 2010 at 4:02 pm
    Just install Compressor from your install disks, and follow Rafael’s suggestion.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Grant Wilber
    September 15, 2010 at 4:05 pm
    I dont have compressor and everything is rendered.
    Whats a Pro Res Master? I tried exporting it as Pro Res instead of H.264 but that didnt make a difference. Does it matter if its .mov or something else?
    I never have problems exporting so I have no clue whats going on. And as I mentioned the video that is not color corrected plays perfect in the export so I know that its not my computer or anything. All the other video is just choppy and doesn’t look that clean.
  • Rafael Amador
    September 15, 2010 at 5:42 pm
    make sure before that EVERYTHING IS RENDERED: Select all, Optio-R.
    I think these CC shots are not rendered.
    rafael
  • Grant Wilber
    September 15, 2010 at 6:24 pm
    Yea they are. The timeline has the blue-gray line above everything that I’ve put a color correction filter on
  • Alex Elkins
    September 15, 2010 at 9:21 pm
    Press CMD+0 to open Sequence Settings.
    1. Under the tab, ‘General’ what does it say below QuickTime Video Settings?
    2. Under the tab labeled ‘Render Control’ are the first two drop-down lists set to 100%? They should be, but what you’re describing sounds as though one of them may be set to 50%.
    Alex Elkins
    Salad Daze Films – Freshly Tossed
    Check out my latest addition to the Creative Cow Reels Section
  • Grant Wilber
    September 16, 2010 at 8:03 pm
    Alex I will name my first child after you.
    That was exactly it. Must of changed it thinking it was only effecting timeline playback. Thank you thank you thank you.
