Activity Forums Apple Final Cut Pro Legacy export .IMX with none fields
  • export .IMX with none fields
    Posted by Michele Stocco on January 31, 2014 at 12:50 pm
    Hi there, as I can’t find an answer on the web and neither on the mighty Creative COW I try it with a new post.
    I’m trying to export a .MXF file from FCP 7, with IMX 625 compression. I’ve succeded to do it with the Sony XDCAM plugin without any problem, but I can’t set the fields right.
    The timeline is progressive/none fields (that’s what the broadcaster is asking, and the orginal footage is progressive) but the .MXF that creates is always upper fields, no matter what I do.
    Any suggestion? I know that if I import the .MXF in FCP I can change the fields settings in the browser, resolving the interlacing problem, but the broadcasters use AVID and they ask specifically for progressive .MXF
    Is there a way to export a .imx clip from FCP with none fields?
    Thanks in advance!
    Michele Stocco
    Editor/Post-production technician
    Michele Stocco replied 12 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
