Activity Forums Adobe Premiere Pro Export impossible
  • Export impossible
    Posted by Philippe Verdoni on April 16, 2025 at 3:30 pm
    In Adobe Premiere Pro 2023, I’m unable to export a sequence, but if I copy and paste all the elements from that sequence into a new sequence, the new sequence exports without any problems.
    I notice that the only difference between these two sequences is the color of the line at the top of the timeline:
    • The line is green in the sequence that doesn’t export,
    • The line is yellow in the sequence that exports without difficulty.
    This is surprising because the green line normally means the sequence is ready for export, while the yellow line indicates that the sequence may not be optimal and that rendering is recommended.
    Thank you for your assistance
    Eric Santiago replied 1 year, 4 months ago 3 Members · 3 Replies
  • Mary Gerber
    April 16, 2025 at 3:48 pm
    Sorry to state the obvious but just to ask, did you render the sequence out? Did you restart the computer and relaunch PP. Restart is usually what works for me. I had this problem in V24 and downgraded a lot of my projects to V23 correcting the issue before jumping onto V25. So far so good with V25
  • Philippe Verdoni
    April 17, 2025 at 7:01 am
    Hi Mary, yes I rendered my project before trying to export it, fortunately the export has only been possible after I had copied all rushs into a new sequence. The question is why is the export working into this new sequence. Thank you for your advice about PP V25; I will try this new issue ofPP. Have a good day
  • Eric Santiago
    April 17, 2025 at 1:17 pm
    Same sequence settings?
    Duplicate the problem sequence and remove data.
    Add new clips or diff variations of current data and see if it exports.
    Pretty odd issue.
