Activity Forums Adobe Media Encoder Export Image Sequences to Sub-Folders
  • Export Image Sequences to Sub-Folders
    Posted by Sean Franklin on June 1, 2016 at 5:00 pm
    Hi all,
    Is it possible to have Media Encoder automatically generate sub-folders to export image sequences to? I have a set of video files that I need to convert to image sequences but do not want to manually create subfolders for each sequence.
    How is this done within Media Encoder?
    -Tim
    Tim Franklin
    Watchout System Programmer/Compositor – CBS Sports
    Freelance Visual Effects Artist/ Video Editor
    http://www.TimSFranklin.com
    Oki Pienandoro replied 10 years, 3 months ago 2 Members · 1 Reply
  • Oki Pienandoro
    June 2, 2016 at 6:27 pm
    Yeah, you can’t do that in AME, however, in AE, it will generate subfolder for each comp/footage if you encode to image sequence.
    You didn’t need to put them in comp, just load the footage into project then add them into render Queue (Ctrl+Shift+/) AE will generate the comp automatically.
    Sorry for the english, not native speaker.
