Activity › Forums › Apple Final Cut Pro Legacy › Export image sequence (TIFF) with 2.2 Gamma
  • Export image sequence (TIFF) with 2.2 Gamma
    Posted by Francis Thomas on January 23, 2010 at 12:56 am
    In FCP 7, when exporting a Prores clip as an image sequence in TIFF format, the TIFFs are automatically converted to 1.8 gamma. Does anyone have a solution on how to export an image sequence without converting the gamma? In other words, I need the resulting image sequence (TIFF/RGB) to have the same gamma (2.2) as the original Prores clip.
    FT
    Arnie Schlissel replied 16 years, 8 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    January 23, 2010 at 5:29 am
    You might be able to do this with Compressor. It can output a tiff sequence at whatever resolution you prefer, and there is a gamma filter. You should run a test and take a look in the PDF Compressor manual.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
